[SOLVED] VEX - addpoint randomly on geo
cgcris
Hi guys,
I am trying to replicate the scatter behaviour, when plugin something like a grid.
Using VEX, what's the best way of adding a point on a geometry randomly?
Thanks,
Cris
Edited by cgcris
You can pre-generate N points using Point Generate SOP, then generate a random integer from 0 to nprims(1)-1 using something like ptnum and a random position (using another seed) and then feed these into primuv VEX function for the second input. This will move your points randomly over a surface.
set your wrangle in detail mode and connect your geo to the second input
int prims = nprimitives(1);
int count = chi("count");
float seed = clamp(chf("seed"),1E-3, 1E8);
for(int i=0; i<count; i++){
    float rr = random(prims*i*seed);
    int prnum = int(rr*prims);
    float u,v;
    u = rand(i*seed);
    v = rand(i*rr*seed);
    vector pos = primuv(1, "P", prnum, set(u,v,0));
    addpoint(0, pos);
just noticed that I wasn't using the correct variable to initialize my for loop
It s fixed now ^^
Edited by holycause
Hi Guys,
Thanks a lot for your replies, now looking at the code Ruben.
There is one line that doesnt work, I am guessing is a typo
// should be
float rr = rand(prims*i*seed);
weirdly when using random the value doesn't update when changing the seed.
Thanks for your help putting this together!
Best,
Cris
