[SOLVED]Assign Expression To A Numeric Parm?
Atom
Hi All,
I am trying to assign an expression to a parameter using python. I want to link two objects together.
I get a type error "Cannot set a numeric parm to a non-numeric value."
I understand I am trying to assign a string to a number field, but the string contains the expression.
Is this possible in using the current python in Houdini 15.5?
Here is my code so far...
trc_source = "/obj/trc"
trc_target = "/obj/angela_1_T_pose_fbx"
lst_source_blocks = ["Root"]
lst_target_blocks = ["hip_To_abdomen"]
for (i,name) in enumerate(lst_source_blocks):
    source_candidate = "%s/%s" % (trc_source, name)
    n = hou.node(source_candidate)
    if n != None:
        target_candidate = "%s/%s" % (trc_target, lst_target_blocks[i])
        m = hou.node(target_candidate)
        if m != None:
            s = '`ch("%s/%s/tx")`' % (trc_source,name)
            m.parm("tx").set(s)
Edited by Atom
You can use hou.Parm.setExpression() http://www.sidefx.com/docs/houdini15.5/hom/hou/Parm#setExpression to set an expression.
Alternatively you can actually set parms to other parms and it will automatically create channel references for you:
tx = hou.parm("/obj/geo1/tx")
ty = hou.parm("/obj/geo1/ty")
ty.set(tx)
