AlphaJoe Posted July 15, 2016 Share Posted July 15, 2016 Is it possible to list out the variable values being generated from a stamp coming from a copy node? I have an expression that is causing me issues, but I can't quite figure out what is wrong because I can't see what values are being generated for each stamp. Quote Link to comment Share on other sites More sharing options...
fencer Posted July 15, 2016 Share Posted July 15, 2016 write them to attribute Quote Link to comment Share on other sites More sharing options...
AlphaJoe Posted July 16, 2016 Author Share Posted July 16, 2016 That worked, sort of. It just made for a really long list. I did an attribute create and wrote the variable value to it before the copy, but when I look a the geometry spreadsheet, it shows that value for every point on the geo that I copied/per instance. I worked around it by temporarily throwing a scatter node with one point in it to replace the stamped geo and that gave me one row per stamp. Thanks for the help. I got the issue with my expression worked out. Quote Link to comment Share on other sites More sharing options...
