Lukich Posted March 26, 2005 Share Posted March 26, 2005 Do you guys know if it's possible to generate particles on subframe level? I 'm generating particles based on a color of a very fast moving image sequence - particles generated per frame just can't catch up with it. Thanks a lot, Luka Quote Link to comment Share on other sites More sharing options...
Jason Posted March 26, 2005 Share Posted March 26, 2005 Do you guys know if it's possible to generate particles on subframe level? I 'm generating particles based on a color of a very fast moving image sequence - particles generated per frame just can't catch up with it. Thanks a lot, Luka 17113[/snapback] Look at the POP Network's parameters; you'll see an Oversampling parameter. Turn that up for subframe goodness. Quote Link to comment Share on other sites More sharing options...
Lukich Posted March 26, 2005 Author Share Posted March 26, 2005 Cool, Jason! Thanks! Quote Link to comment Share on other sites More sharing options...
doc Posted March 28, 2005 Share Posted March 28, 2005 Cool, Jason! Thanks! 17115[/snapback] Hi Luka You might try turning your oversampling back to 1, and turning accurate births on in your source POP instead. The thing about oversampling is that all of your pops will cook for each oversample which may not be what you want(ie it make take too long to cook). Accurtate birth only affects the source not your other pops Cool name by the way, but I think you've misspelled it All the best Luca with a "C" Quote Link to comment Share on other sites More sharing options...
