Syntax error, unexpected integer constant, expecting ")"
art3mis
Trying to follow a basic VEX tutorial and in the following line the '0' is highlighted
int addprim(0,"poly");
and I get the following error
I'm on a Mac running 15.5 Apprentice.
AFAIK, my code is correct. Anyone?
The description in the docs do not show an example but the function prototype. That means it shows which arguments the function expects and what type it it returns. The error message is confusing just because Houdini tries to interpret what you are writing. So it sees something like this:
int someName(...)
With something like that you normally start the definition of a vex function and vex functions do not allow a constant int as argument (what would be useless anyway). And so the function definition is not correct what leads to this error message.
