Guest tar Posted July 20, 2016 Share Posted July 20, 2016 Quick question. Is there any barrier to having a VR lens shader in the OpenGL viewport? Shader Toy talks about it: Shadertoy shaders can create images for Virtual Reality (VR) mediums seamlessly. For that shaders must implement the mainVR() entry point, which is optional and has this prototype:void mainVR( out vec4 fragColor, in vec2 fragCoord, in vec3 fragRayOri, in vec3 fragRayDir )where fragCoord and fracColor work the same as in regular 2D image shaders: they contain the pixel coordinates in surface space and the output pixel color.the variables fragRayOri and fragRayDir contain the ray origin and ray direction of the ray that goes through that pixel in the virtual world, given in tracker space. The shader is expected to transform these values into camera space if a moving camera is to be moved though the virtual world. The ray origin is given as variable and not uniform for VR systems where the camera is not modelled as a pinhole camera.Shaders that implement the mainVR entrypoint will automatically be flagged as VR ready and will be searchable though the filter system under the VR qualifier. https://www.shadertoy.com/howto Quote Link to comment Share on other sites More sharing options...
malexander Posted July 20, 2016 Share Posted July 20, 2016 The main barrier is performance, the lens shaders themselves are pretty simple. Maintaining 90fps at all times when we don't have any control over what is displayed, is the main problem. I suspect we'd have to severely restrict how things are displayed when in any sort of "VR" mode (shaded only, normal quality lighting, no visualizers, etc). Quote Link to comment Share on other sites More sharing options...
Guest tar Posted July 20, 2016 Share Posted July 20, 2016 Cool. Thanks! Makes sense. Found a 3d roller coaster examples at https://vr.chromeexperiments.com/ Using Nuke's CaraVR tools I'm kind of getting used to looking at LatLongs in the 2d viewport to make some judgments. Crazy thoughts but could that every happen in the Houdini viewport? a LatLong openGL shader even if it's low performance. Quote Link to comment Share on other sites More sharing options...
malexander Posted July 20, 2016 Share Posted July 20, 2016 That sort of display is more appropriate for the OpenGL ROP and Flipbooks. In the viewport, it makes selecting things rather challenging Quote Link to comment Share on other sites More sharing options...
Guest tar Posted July 21, 2016 Share Posted July 21, 2016 Done! Rfe'd as #76680 Thanks Mark. Quote Link to comment Share on other sites More sharing options...
sebkaine Posted August 5, 2016 Share Posted August 5, 2016 i second that Marty ! Having the ability to open a VR preview canvas, that open an OpenGL view with a camera compatible with standard HMD would be great. To have those 2 option would be cool : 1 - Direct HMD access from houdini like UE4 VR preview https://docs.unrealengine.com/latest/INT/Platforms/Oculus/QuickStart/5/index.html 2 - Extend display with standard Android sensor recognition https://developer.android.com/guide/topics/sensors/sensors_motion.html 1 Quote Link to comment Share on other sites More sharing options...
Guest tar Posted September 10, 2016 Share Posted September 10, 2016 Looky look - LatLong viewport in SynthEyes Quote Link to comment Share on other sites More sharing options...
ameyer Posted May 11, 2018 Share Posted May 11, 2018 On 21.7.2016 at 2:35 AM, tar said: Done! Rfe'd as #76680 Thanks Mark. Hey Mark, what do you mean with Done? Did you find a solution for it? Would be very interested in it. Thanks Adrian Quote Link to comment Share on other sites More sharing options...
