Working with small camera
Yon
hi,
first time working with a tracked camera and footage in Houdini.
the camera was made to work with cm I'm guessing, its movement is very small.
how do you scale it so you can work with meters in Houdini?
I'm sure some one has gotten work from maya to build on that was in cm, but we need to work in meters in Houdini!!
thanks if you can help!
4 minutes ago, Yon Anadeyo said:
thanks michael, I attached null to camera and scaled by 100 and its all good
If you render through this camera you will encounter tons of issues. Never scale a camera directly, just scale the transforms.
  • Like 2
