Jebbel Posted August 12, 2016 Share Posted August 12, 2016 Hi all! Maybe this is a very stupid question... but it seems to be a difficult thing to do so here goes; Is there an easier way to output depth maps for After Effects? I now have to import my renders into Houdini and put them through a comp network to equalize the values to get a usable rgb map. importing directly from Houdini into After Effects results in a black and white map with no detail in between. How do you guys do it? cheers, Jeffrey Quote Link to comment Share on other sites More sharing options...
Shinjipierre Posted August 12, 2016 Share Posted August 12, 2016 The values are above 1, you have to work with 16-32 bits EXRs to get the proper values. Also, after effects has to be set correctly (I think it's 8bits by default) Quote Link to comment Share on other sites More sharing options...
Atom Posted August 12, 2016 Share Posted August 12, 2016 (edited) Are you adding an extra image plane with the Shading Depth (Pz) checked? I see a fairly nice gradient range on a simple depth scene. ap_mantra_depth_map.hipnc Edited August 12, 2016 by Atom Quote Link to comment Share on other sites More sharing options...
Jebbel Posted August 12, 2016 Author Share Posted August 12, 2016 6 minutes ago, Shinjipierre said: The values are above 1, you have to work with 16-32 bits EXRs to get the proper values. Also, after effects has to be set correctly (I think it's 8bits by default) Hi all, Thanks for your replies. I've tried 32bit across the board and it still loads as a single color. When I put it through a comp network and use equalize...then I get some range back. I have no problem exporting a depth map. It's the import that's difficult; specifically After Effects. it's also red...which seems weird :P. See attached "equalized" output. Quote Link to comment Share on other sites More sharing options...
adrianr Posted August 12, 2016 Share Posted August 12, 2016 It's red because Zdepth is just one channel of information. It only needs the R component of RGB, R is the first component, ergo, red You could put the information in all channels to give you a black and white image but it's 2 channels of unnecessary information (I'm not sure what you're using in AE for your defocus but can you not just select a channel to use for depth information?). Quote Link to comment Share on other sites More sharing options...
Jebbel Posted August 12, 2016 Author Share Posted August 12, 2016 I think I just solved my own problem :P. When you use EXRtractor to pull out the Z pass I need to go out pretty far on the white point value. at around 300 I start to see my gradients Quote Link to comment Share on other sites More sharing options...
Jebbel Posted August 12, 2016 Author Share Posted August 12, 2016 Thanks a bunch guys for steering me in the right direction Quote Link to comment Share on other sites More sharing options...
