novice - modify point inside SORT SOP
art3mis
I played a lot with point sorting and it's really useful when it works as you want it too, but that's not always the case. ;)
It might be a better solution to create a transitional point attribute, arrange it's values as you want, then use that attribute in a sort - that will give you a lot more control.
Edited by Farmfield
I would propose it's more like a staircase - it's not really complicated per small piece, but there's just an endless amount of small pieces. :D
But Houdini is amazingly consistent, so almost everything you learn will be applicable in many places.
