djpeanut Posted April 9, 2005 Share Posted April 9, 2005 Hi, again (!) I've got a piece of geometry shaded with a VEX Super Material shader, and it's representing a water surface so it's pretty reflective. I'm also trying to render in a depth plane using Deep Raster in Mantra so I can generate some background fog in COPs. But the reflective surface gives me lots of depth plane artifacts, meaning that I get lots of little white patches when I apply the Fog COP. Anyone have any ideas for how to stop this? I just want the water geo to return it's own depth, not that of stuff reflected in it. Quote Link to comment Share on other sites More sharing options...
edward Posted April 9, 2005 Share Posted April 9, 2005 Maybe you can render the water in a separate pass without reflections. You can then do a Zdepth composite. Quote Link to comment Share on other sites More sharing options...
sibarrick Posted April 9, 2005 Share Posted April 9, 2005 Are you sure they aren't holes? do you have displacement on your water. Try turning up displacement bounds if you do. Displacements are the root of all evil if you don't know what they are doing in the renderer. Good thing to read up on. Quote Link to comment Share on other sites More sharing options...
malexander Posted April 10, 2005 Share Posted April 10, 2005 If you do end up with a few holes, you could use a Median filter (Median Cop) to remove the specks. But your image shows large bands of 'bad' depths, so you'd still be stuck with those. If all else fails, try rendering out your scene as a Z map only, minus reflections and anything fancy, and see if the artifacts are still there. Quote Link to comment Share on other sites More sharing options...
djpeanut Posted April 10, 2005 Author Share Posted April 10, 2005 sibarrick said: Are you sure they aren't holes? do you have displacement on your water. Try turning up displacement bounds if you do. Displacements are the root of all evil if you don't know what they are doing in the renderer. Good thing to read up on. 17447[/snapback] No, there's no displacement happening, it's just a grid with a Point SOP with some expressions rendered as subd. I'll try and figure out that Z-depth compositing stuff you people keep mentioning Thanks! Quote Link to comment Share on other sites More sharing options...
djpeanut Posted April 16, 2005 Author Share Posted April 16, 2005 malexander said: If all else fails, try rendering out your scene as a Z map only, minus reflections and anything fancy, and see if the artifacts are still there. 17460[/snapback] Erm... how do I render out a Z map only? Quote Link to comment Share on other sites More sharing options...
Jason Posted April 16, 2005 Share Posted April 16, 2005 djpeanut said: Erm... how do I render out a Z map only? 17572[/snapback] Hey djpeanut, You can ask mantra to render it by putting a -Z on the commandline in the Mantra ROP. One thing to be aware of, though, is that mantra will antialias the edges of your objects and thus you end up with z values which don't make any sense on the edges. This is because it antialiases to black, which in a z image is right on the camera. To get around this, you may find that you'll have to unpremultiply the Z depth map in COPs (or whereever you're comping). ZDepth compositing usually leads to all kinds of badness due to things like these. Motion-blur and internal edges (not the silhouette edge) will suffer from antialiasing too. Having one pixel, filtered or unfiltered, is not enough information to reconstruct built-in z-depth effects in many cases. Post your results:) Quote Link to comment Share on other sites More sharing options...
djpeanut Posted April 16, 2005 Author Share Posted April 16, 2005 Thanks Jason, I'll post some results when I try it out tomorrow. Quote Link to comment Share on other sites More sharing options...
