is it possible to submit takes to distributed sim/rendering?
Hi odforce
I have this issue that i cant get "takes" to work with distributed rendering. I have tried with Deadline and HQserver and both get the same issue, they cant "modify" the parameters in the takes because they are locked.
I have tried using wedge (telling the distributed renderer that i submit it with a wedge) and i have tried to submit it with just changing the take in the rop itself.
Is the take system only meant for rendering on your local machine or am i missing something?
As a sidenote, why do HQserver need $HIP or $JOB in the filename when the path is allready accesible to the rendermachines?
And why do you have to install the repository on the same partition as the project itself?
I hope someone out there knows a solution on this (or have any other clever idea on how to work with different sim settings), because its a bit cumbersome to not be able to use takes when siming.
regards Thomas
