Using VDB SDF's distance value, how do I make particles lying on some range of surface?
aesthete
Hi guys.
I've been trying to make particles snap onto surface using vdb sdf.(volume sample and gradient)
Specifically, I am trying to emit the particles from sdf volume and let them lie on some range of a surface.
I know how to snap particles on a surface but what I really want to make is exactly not that all particles stick on the surface.
I want some particles to lie down a short distance away from the surface outside or inside.(randomly)
It may be softball question but I can't get easily figured out…
Any suggestions would be appreciated!
lee
prac_sdf_distance.hip
Here's one way. I give each particle a random sdf target,  subtract the current sdf value from that, and use that to scale each particle's velocity.
To make it easier to tweak I've run the sdf_target value through a ramp, then a fit range, so you can determine the min+max sdf values you want, and the distribution of those values.
prac_sdf_distance_mestela.hipnc
Thank you so much for your replying and the hip file. I did not even know that using particle's velocity can make them lied on what I determined!
If you don't mind, I have another question.
After trying out the way you suggested, I also wanted to make the particles move around on each particle's surface where they lie on.
It's like P + ((normalized gradient * negate) * (signed distance))
gives the result that particles are snapped onto the surface and slightly move around the surface.  How can I do this?
