video as background reference?
catchyid
I have a video that I want to display as a background video to a camera, is this possible in Houdini? I can display a background image, but a video does not seem to work? As a workaround, I am converting the video to image sequence so it can be loaded ...
Update: When I used an image sequence (png), playback becomes really slow, to make it worse it's an empty scene! Is there anyway to improve playback speed?
Thanks
Edited by catchyid
Try using a half size JPEG version image sequence with mild compression. The smaller the file the quicker the update. No matter what you probably will never get realtime playback. But I understand the need for smoother scrubbing. Press the D-KEY to bring up the viewport display dialog. Under the Background tab you can change the image brightness, and quality.
  • 5 years later...
