Juzwa Posted September 18, 2016 Share Posted September 18, 2016 Hi, So I dont know how to setup for my cloth to do tearing (fracturing). I created point attrib fracturepart = -1 on points where I want the tearing to happen, and 0 (nonnegative integer) on all other. Enabled the fractiring and nothing happens. I have an idea that I should probably use sop solver to fracuture the geometry. Like breaking constraints in bullet, I did that once but dont remember how it was done. I actually dont understand the logic behing using solvers, that seams to be too complicated for my brain So how should this be done? TearingClothTest_v001.hipnc.hiplc 1 Quote Link to comment Share on other sites More sharing options...
Juzwa Posted September 18, 2016 Author Share Posted September 18, 2016 (edited) Ok I managed to get it working. So it looks like you dont have to create fracturepart attribute at all. I dont know why its said in help you have to. What controls the tearing is fracturethreshold attrib (per point). And once this goes under Fracture Threshold * -1 (defuault 0.1 whould be -0.1) the fracture will happen. At least this is how I understand it And a file if you want to check it out (sorry for hiplc format I dont know if this open in apprentice too) TearingClothTest_v002.hiplc Edited September 18, 2016 by Juzwa 4 Quote Link to comment Share on other sites More sharing options...
anthonymcgrath Posted September 23, 2016 Share Posted September 23, 2016 just had a play with your scene and yeah thats cool - seems to work nicely - changing the 5 value in the fit range to larger gives less of a shredding tear too nice work i've just tried adding this same trick into my own fem fracturing sim but sadly it wasn't doing what i hoped for Quote Link to comment Share on other sites More sharing options...
anthonymcgrath Posted September 23, 2016 Share Posted September 23, 2016 1 Quote Link to comment Share on other sites More sharing options...
