difference between creating name attributes?
lyansart
Not sure if there is any difference. I also couldn't find anyway to NOT create the name attribute in the voronoi fracture.
I ran a test using an attribute wrangle to create an attribute called oldname and assigned it the value of name before the assemble, and they were the same, which is what I thought would happen.
A common fracturing technique is to do a basic fracture, then use a for each loop for each piece with one point feeding a voronoifracturepoints. This gives you the ratio of small bits to larger chunks. The name attribute from the first fracture and the second one will be mixed afterwards, this is a case when you need to create a new name attribute from the assemble SOP.
