kubabuk Posted April 20, 2005 Share Posted April 20, 2005 Any idea, how can I create swf file withinin houdini, or the shortest way to do this with conjunction with other software... Quote Link to comment Share on other sites More sharing options...
edward Posted April 20, 2005 Share Posted April 20, 2005 Render out a sequence of images and combine them into some movie format that works with flash? Quote Link to comment Share on other sites More sharing options...
Guest Guest Posted April 22, 2005 Share Posted April 22, 2005 my guess is he wants vector output into swf.. Quote Link to comment Share on other sites More sharing options...
kubabuk Posted April 22, 2005 Author Share Posted April 22, 2005 Yes, that's right I'm interested in vector output in houdini - but I suspect, it's not possible yet... Quote Link to comment Share on other sites More sharing options...
Jason Posted April 22, 2005 Share Posted April 22, 2005 Anything is possible I can think of a few ways to get this working - each not the easiest, but what can you do.. and how you want to render it. */ Use the Wren ROP to render your wireframes to postscript format - which is a vector format. Now by hook or by crook you can force this into SWF I'm sure. There might even be a converter out there for PostScript->SWF. */ Render it out using Mantra and use a vectorizing program to convert the final renders to filled vectors - Illustrator / Freehand or whatever. */ For wireframe only, do you own mangling of the myriad of ASCII geometry output you can spit out of Houdini. Quote Link to comment Share on other sites More sharing options...
Andz Posted April 22, 2005 Share Posted April 22, 2005 Jason - Render it out using Mantra and use a vectorizing program to convert the final renders to filled vectors Yep, Macromedia Flash can do that and it works perfectly, specially if you use toon shaders. Quote Link to comment Share on other sites More sharing options...
