dxhhx Posted September 27, 2016 Share Posted September 27, 2016 Hey guys, I'm having a weird problem where my scene renders properly in Houdini, but when I save an IFD with Mantra and renders on the farm, the shaders doesn't show up (all gray).. Does anyone have an idea what might be the issue? Thanks! I probably won't be able to share the file.. Here is a snippet of errors I get when I render the IFD locally: Quote Link to comment Share on other sites More sharing options...
Hokmah Posted September 29, 2016 Share Posted September 29, 2016 try to change this parameter on(bottom of screen): Save All Material SHOPS and see if it is working. I'm usuing Qube for sumbiting my jobs and it is working without it but maybe in your case you have to make it. Quote Link to comment Share on other sites More sharing options...
martinT Posted December 6, 2016 Share Posted December 6, 2016 Hi, Small disclaimer: I'm not sure I'm doing this the correct way and I'm using Deadline. What I have to do when rendering edited/custom shaders I need to "save node type", and "match current definition" before I submit my ifds to rendering. Could anyone else confirm that's the correct workflow? Quote Link to comment Share on other sites More sharing options...
