new houdini install won't run on fresh CentOS 7 install
I just installed CentOS 7. I downloaded and installed Houdini. When I try to run Houdini I get the splash screen and then it crashes. I have an nvidia GTX 970 graphics card.
I'm using the default nouveau driver. I have not installed any graphics drivers. I hope that's not my problem/solution. I googled how to install the nvidia drivers on CentOS 7 and it looks like a scary world of pain. I've tried running Houdini from the command line, and from the start menu thingy, and it crashes both ways.
Any ideas? Anyone?
Here is the crash report from the /tmp folder:
$ cat crash.untitled.jpatterson_4929_log.txt
Crash report from jpatterson; Houdini FX Version 15.5.607
Uptime 0 seconds
Sat Oct 1 11:52:14 2016
Caught signal 11
Traceback from 4929 ThreadId=0x7f413ff0b300
AP_Interface::coreDumpChaser(UTsignalHandlerArg) <libHoudiniUI.so>
AP_Interface::si_CrashHandler::chaser(UTsignalHandlerArg) <libHoudiniUI.so>
signalCallback(UTsignalHandlerArg) <libHoudiniUT.so>
UT_Signal::UT_ComboSignalHandler:yikes.pngperator()(int, siginfo*, void*) const <libHoudiniUT.so>
UT_Signal::processSignal(int, siginfo*, void*) <libHoudiniUT.so>
_L_unlock_13 <libpthread.so.0>
QReadWriteLock::lockForWrite() <libQtCore.so.4>
QGLWidget::deleteTexture(unsigned int) <libQtOpenGL.so.4>
QGLContext::~QGLContext() <libQtOpenGL.so.4>
QGLWidget::~QGLWidget() <libQtOpenGL.so.4>
re_QGLWidget::~re_QGLWidget() <libHoudiniUI.so>
QObjectPrivate::deleteChildren() <libQtCore.so.4>
QWidget::~QWidget() <libQtGui.so.4>
re_QWindowWidget::~re_QWindowWidget() <libHoudiniUI.so>
RE_QtWindow::~RE_QtWindow() <libHoudiniUI.so>
UI_Window::~UI_Window() <libHoudiniUI.so>
QT_Window::~QT_Window() <libHoudiniUI.so>
FUSE_AnonymousStats::~FUSE_AnonymousStats() <libHoudiniAPPS3.so>
FUSE_App::~FUSE_App() <libHoudiniAPPS3.so>
FUSE_HoudiniBinariesApp::~FUSE_HoudiniBinariesApp() <libHoudiniAPPS3.so>
__run_exit_handlers <libc.so.6>
__GI_exit <libc.so.6>
UT_Exit::doExit(int, bool) <libHoudiniUT.so>
RE_OGLRender::initGLState() <libHoudiniUI.so>
RE_OGLRender::makeCurrent(bool) <libHoudiniUI.so>
RE_OGLRender::lockContextForRender() <libHoudiniUI.so>
RE_QtWindow:yikes.pngpenWindow(int, int) <libHoudiniUI.so>
QT_Window::doOpen() <libHoudiniUI.so>
UI_Window::handleEvent(UI_Event*) <libHoudiniUI.so>
UI_Queue::processNextEvent() <libHoudiniUI.so>
UI_Queue::drain() <libHoudiniUI.so>
UI_Queue::drainEvents(bool, bool) <libHoudiniUI.so>
OPUI_MainApp::loadFilesAfterUiOpen(UI_Event*) <libHoudiniAPPS2.so>
UI_Queue::eventLoop() <libHoudiniUI.so>
main <libHoudiniUI.so>
__libc_start_main <libc.so.6>
_start <houdini-bin>
I was just about to install an Nvidia proprietary driver.  So, if I install kmod-nvidia, I don't have to reinstall with every kernel update?  That got old in ubuntu, until I ran across a solution, which I don't remember.
I installed elrepo.  Seems like it worked.
I went to the elrepo kmod page you posted, and it suggests doing these commands:
yum install nvidia-detect -OR- yum update nvidia-detect
nvidia-detect
rpm -qa | grep nvidia
When I run the last line the output is this:
[root@darkczar ~]# rpm -qa | grep nvidia
nvidia-detect-367.44-1.el7.elrepo.x86_64
Does that mean I already have nvidia 367 installed?  When I run
lsmod | grep nouveau
I get about 8 lines of output suggesting I'm using the nouveau driver.
On the other hand...
lsmod | grep nvidia
returns nothing.
Question: Can I / should I use the nvidia driver that is installed already? If so, how?
Edited by johnLIC
Well, it's been a long night.  I tried to install kmod-nvidia:
yum install kmod-nvidia-340xx
When I rebooted after that I had no graphics card driver at all.  I then decided to install the Nvidia driver using the download from Nvidia's website.  That failed because I had "secure boot" on my machine.  It started to feel a little like this:
I had to go into the BIOS and turn off the secure boot ( don't tell anyone I did that!)  and then reinstall the nvidia driver, and all is well so far.
rpm -qa | grep nvidia yields this:
but, oddly (to me)
nvidia-detect  yields
kmod-nvidia
So, thanks for the help.  I have no idea what's going on, but hopefully I won't have to deal with this again for a long time.
Ok, then it seems like you're good to go.
It was the secure boot that messed up an otherwise simple process.
And yes, kmod-nvidia means that you don't have to reinstall the driver after kernel updates.
I've been updating many times without any problems.
There is a help page which describes how to make elrepo work with secure boot here:
https://elrepo.org/tiki/SecureBootKey
