voronoi fracture + cracks problem
Guest janosch
Guest janosch
hi, I have another problem
i will hold the fracture-setup in addition I will add cracks on top of this fracture setup.
Later I will fracture this crack pieces, too.
anyone knows this problem?
thank you
crack.hip
It is typically done in two steps, the crack and then the fracture. I played around with a possible fracture setup.
Here are a couple of animated crack links.
http://forums.odforce.net/topic/21328-animated-crevicecrack-render-anomaly/#comment-127116
http://forums.odforce.net/topic/12604-animating-a-crack-up-a-wall-in-houdini/#comment-79252
ap_ground_fracture_with_crack.hiplc
  • Like 2
Guest janosch
hi,
thank you for your reply
I have this ceiling.
the first step is to create lots of cracks around my main piece. Small pieces then crumble away from these cracks.
In the end, the main piece comes down and I want it to be the only big Element the breaks off the ceiling.
