shop_displacepath on per primitive base?
Hi there,
I'm trying to wrap my head around renderman 20 in houdini 15.5.
Now there's a tricky thing with displacements going on.
When building stuff, I usually group the entire object in a single geometry node
via subnet and combines, applying materials via the material SOP and specific groupings of the
underlying geometry. this in turn creates a string attribute on the selected primitives
with name “shop_materialpath” and the given path to the pxrWhatever shader.
stuff shows up in RIS renders, everything behaves as expected. fine.
this would behave equally, if I just added the “shop_materialpath” via AttributeCreate and
the proper path to the shader by hand on a primitive.
however, now I want to displace something.
the only working way in renderman 20 seems to be to create a pxrDisplacement with some input
(f.e. pxrWorley) and add the rendering parameters “Displacement Shader” (shop_displacepath)
and “Displacement Bound” (ri_dbound) to the geometry node in /obj.
Apply the shader, set bound > 0, displacement shows up in renders. fine.
BUT:
Now I thought: “Hah. Just transfer these parameters on a primitive base via AttributeCreate as well, done.”.
However this doesn't seem to work. Instead I have to extract the geo into a second geometry node
in /obj via ObjectMerge and again apply the said parameters on the top-level geometry node itself.
Are “shop_displacepath” and “ri_dbound” not assignable to primitives by hand?
Or am I missing a crucial step? Perhaps something else has to be applied as well?
-Marcus
  • 2 years later...
