lanchka Posted April 28, 2005 Share Posted April 28, 2005 I guess the topic says it all. What would be the fastest way to render a frame range to avi or any other video format? Cheers Lanchka Quote Link to comment Share on other sites More sharing options...
hoknamahn Posted April 28, 2005 Share Posted April 28, 2005 If you using Windows check mcp (in Houdini's bin directory) or Virtual Dub. Under Linux you can use mencoder or ffmpeg. Quote Link to comment Share on other sites More sharing options...
crunch Posted April 28, 2005 Share Posted April 28, 2005 hoknamahn said: If you using Windows check mcp (in Houdini's bin directory) or Virtual Dub.Under Linux you can use mencoder or ffmpeg. 17876[/snapback] It's also covered in the wiki: http://odforce.net/wiki/index.php/CreatingMovieFile Quote Link to comment Share on other sites More sharing options...
