ndeboar Posted October 13, 2016 Share Posted October 13, 2016 Hey, I am trying to do a simple "water pouring in to a glass" sim. From my understanding, Houdini works in meters, so I am making sure everything is the correct scale. I watched some tutorials that used particles to emit flip fluids, but it seems the particle system has completely changed from the version they where using to how it looks now in H15. So, as a starting point, I tried using the shelf tool "Emit Particle Fluid", and that doesn't seem to work. The fluid does not fall. See attached hip file. Can someone point me in the right direction? I am not sure what the best learning path is. Thanks, Nick sim_v01.zip Quote Link to comment Share on other sites More sharing options...
vijay_7363 Posted October 13, 2016 Share Posted October 13, 2016 scale of the sphere is very low(0.025), make it 1 or at least 0.5 and it will do fine. or you can use particle separation of 0.02 to have enough density of particle in the grid to emit. but i think scale of 1 will give you proper result. Quote Link to comment Share on other sites More sharing options...
ndeboar Posted October 13, 2016 Author Share Posted October 13, 2016 Hey Vijay, A scale of 1 would = 1 m. That is a pretty big tap! I am trying to work in real world units. Are you saying I shouldn't work in real world units? Ta, Nick Quote Link to comment Share on other sites More sharing options...
dimovfx Posted October 13, 2016 Share Posted October 13, 2016 Regarding liquids, there is a sweet spot in scale that they work fine without glitches. The scale shouldn't be too small or too big because the numbers that solver has to evaluate can get too small or too big. You'll have to feel when the scale is right, so you might want to try same setup with different scales and and see where it works best. After that you can compensate scale with gravity. At least this is what I would do. Hope that helps. Cheers. Quote Link to comment Share on other sites More sharing options...
girtab Posted October 13, 2016 Share Posted October 13, 2016 hi i make a simple water sim you can see my method and try to change value. sim_v01.hiplc Quote Link to comment Share on other sites More sharing options...
