Hair surface penetration
Juzwa
So Im having problems with hair penetarting the collision surface. The simulation itself is very good, there is no penetation of the guide curves.
The penetration happens on the hair object - and ofcourse it happens, is just uses my simed curves as guides. I tried different settings but nothing really helps, I can still see the ugly penetration.
Maybe I should do some kind of postprocess effect, to push out the hair from the surface. But then, how can I do that?
Here is a vid, you can see the penetartion on scalp in 00:01 - 00:02:
Here is the hip file and obj file for the guides (I use external geometry for guides, but I think it should work the same with scattered guides)
https://dl.dropboxusercontent.com/u/22676624/HairPenetration.zip
Edited by Juzwa
