VEXing array question - SOLVED
kev2
If I use an attribute wrangle to create an array attribute and populate the array like so:
i[]@stuff = nearpoints (0, @ape, 1, 23);
I can then slice the array like so:
i@branch = @stuff[3];
and all is good in the world.
However, if I attach another wrangle node and try to use the same slice, I get an error even though the array attribute shows up in the spreadsheet?
Not a showstopper but I'd love to know why the attribute isn't accessible.
Edited by kev2
For completeness, all I needed to do was declare the array as itself:
i[]@stuff = i[]stuff;
and then it picks up the array so that i@branch = @stuff[4] works fine now. Thanks @david for the assist.
Edited by kev2
