monokolor Posted October 19, 2016 Share Posted October 19, 2016 Hi guys! I am simulating liquid for my job project about christmas. I can't simulate shape of fluid which would satisfy me. I need liquid with viscosity of milk or somethink more viscous. Another thing I want to achieve is specific shape of fluid (which is presented on examples). I tried simulate this with: geometry, which fell down in to the water tank; emitter and wine glass; POP Curve Force. I am aware that could be kinda noobish question but I ask you to help me investigate where I am making mistake. Quote Link to comment Share on other sites More sharing options...
bifrost Posted October 19, 2016 Share Posted October 19, 2016 (edited) Usually with small scale simulations like these, you need surface tension. At the moment, there is no "direct answer" to that in H but there are some ways to achieve it. Look for "fill holes" technique around the interwebs. Also, you can try dropping a cube in a tank with high viscosity and velocity scale under collisions turned high up. Also, don't forget to switch the solver type from Splashy Kernel to Swirly Kernel as it is optimised to give you smooth results like mentioned above. -bf Edited October 19, 2016 by bifrost 1 Quote Link to comment Share on other sites More sharing options...
monokolor Posted October 20, 2016 Author Share Posted October 20, 2016 Thank you very much, bf. I will check this what you mention. Quote Link to comment Share on other sites More sharing options...
