vlb6 Posted October 22, 2016 Share Posted October 22, 2016 Hi there, Very new to Houdini, I am looking to export volume trails into Cinema 4D, weather by exporting the points or turning the points into splines and then exporting, as long as I avoid geometry because it's dense. Also, I do not have the Houdini engine. Any ideas on how this can be done? Quote Link to comment Share on other sites More sharing options...
Slimesunday Posted October 23, 2016 Share Posted October 23, 2016 use ROP output sop and save your file as .abc. When you import into c4d make sure to check import as splines. Dont make the object editable keep it in alembic format. Quote Link to comment Share on other sites More sharing options...
vlb6 Posted October 23, 2016 Author Share Posted October 23, 2016 10 hours ago, Slimesunday said: use ROP output sop and save your file as .abc. When you import into c4d make sure to check import as splines. Dont make the object editable keep it in alembic format. Thanks very much mate! I was using the 'ROP alembic output' which is the incorrect one and also doesn't work with non-commercial license - the one you suggested worked perfectly. Quote Link to comment Share on other sites More sharing options...
