It will take your pyro sim and re simulate it with a higher voxel count
the low res needs to be cached with vel
ctrl click up res container in the shelf somewhere then select your smokeobject in DOPs and hit enter in viewport
theres option in up res solver to run off a file from disk
Its primary use is to up res without changing the general shape of your low res, re timing and using high frequency turbulence for details.
I don't think it's much more (if any) more efficient then running high res from start. But can be in more complicated sims where there is things acting on your vel field ( dop forces ect). Look at clustering in the manual and shelf as its what makes a difference
  • 2 weeks later...
