maiden666 Posted October 30, 2016 Share Posted October 30, 2016 (edited) Hello. Im interesting to export a Houdini particles to render in Krakatoa, I was looking for an opportunity to do so but I found only a pretty old stuffs like that http://dhel-vfx.blogspot.ru/2010/05/houdini-pop-to-krakatoa-prt.html Is there any new features? To work witn Houdini15. Edited October 30, 2016 by maiden666 Quote Link to comment Share on other sites More sharing options...
Hamp Posted October 31, 2016 Share Posted October 31, 2016 If I remember correctly, you can install realflow to get the BIN exporter, I don't think the plug in needs a license, worth a shot. Then the question is if you *really* need krakatoa, Houdini can also render quite insane amounts of particles. Check out this set of videos from Peter Quint. Quote Link to comment Share on other sites More sharing options...
Yon Posted October 31, 2016 Share Posted October 31, 2016 Look online for the PRT rop from flipswitchingmonkey and put it in your installation folder/dso and it will be in your /out Quote Link to comment Share on other sites More sharing options...
maiden666 Posted November 1, 2016 Author Share Posted November 1, 2016 (edited) 23 hours ago, Hamp said: If I remember correctly, you can install realflow to get the BIN exporter, I don't think the plug in needs a license, worth a shot. Then the question is if you *really* need krakatoa, Houdini can also render quite insane amounts of particles. Check out this set of videos from Peter Quint. Hamp, I watched this video but Krakatoa is render particles 100 times faster cos Houdini is consider particles as a geo objs, while Krakatoa as a pixels Edited November 1, 2016 by maiden666 Quote Link to comment Share on other sites More sharing options...
Hamp Posted November 1, 2016 Share Posted November 1, 2016 Sure, just a suggestion. Use whatever works for you. Quote Link to comment Share on other sites More sharing options...
