evanrudefx Posted November 1, 2016 Share Posted November 1, 2016 (edited) Hi, I am new to houdini, but it seems like this would be simple. How do you open a project using file>open? My file is greyed out. It seems I would go file>open>then select project? Thanks in Advance Edited November 1, 2016 by ejr32123 Quote Link to comment Share on other sites More sharing options...
davpe Posted November 1, 2016 Share Posted November 1, 2016 never seen greyed out scene file like this... should work the way you are used to. Quote Link to comment Share on other sites More sharing options...
Mandrake0 Posted November 1, 2016 Share Posted November 1, 2016 (edited) uhhh that looks strage. is the project on a external storage and uses samba? if yes you need to change the access method: HOUDINI_ACCESS_METHOD need to set in the file: houdini.env you can see more information here: https://www.sidefx.com/docs/houdini/ref/env Edited November 1, 2016 by Mandrake0 Quote Link to comment Share on other sites More sharing options...
Atom Posted November 1, 2016 Share Posted November 1, 2016 You can also double click directly on the .hip file. Or Drag and drop it onto an open Houdini session. Quote Link to comment Share on other sites More sharing options...
evanrudefx Posted November 2, 2016 Author Share Posted November 2, 2016 (edited) 53 minutes ago, Mandrake0 said: uhhh that looks strage. is the project on a external storage and uses samba? if yes you need to change the access method: HOUDINI_ACCESS_METHOD need to set in the file: houdini.env you can see more information here: https://www.sidefx.com/docs/houdini/ref/env Hey! That must be it. I have my project on p: drive, which is a network drive at my school. I tried saving a project on c: drive, and I can open it just fine. I will look into what you said and see if I can get it working on p:. Thanks! Edited November 2, 2016 by ejr32123 Quote Link to comment Share on other sites More sharing options...
evanrudefx Posted November 2, 2016 Author Share Posted November 2, 2016 Hey, I set the houdini_access_method to "2" and now it works properly. Thanks 1 Quote Link to comment Share on other sites More sharing options...
