How To uh... Open a Project?
uhhh that looks strage. :wacko:
is the project on a external storage and uses samba?
if yes you need to change the access method:  HOUDINI_ACCESS_METHOD
need to set in the file:  houdini.env
you can see more information here: https://www.sidefx.com/docs/houdini/ref/env
Edited by Mandrake0
Hey!
That must be it. I have my project on p: drive, which is a network drive at my school. I tried saving a project on c: drive, and I can open it just fine. I will look into what you said and see if I can get it working on p:.
Thanks!
Edited by ejr32123
