jingaa Posted November 3, 2016 Share Posted November 3, 2016 Hello guys i was testing redshift for houdini and couldnt render volume... Does anybody having a problem about that or its just me? I tried to convert the volume to vdb , vdb volume , polygon soup and didnt work. then tried to add ObjParm to geometry and enabled volume parameter and didnt work again. What else i need to do? Quote Link to comment Share on other sites More sharing options...
nbyte Posted November 3, 2016 Share Posted November 3, 2016 Hi Sercan, you need 3 things to render volumes with redshift. 1. Volume should be Houdini Volume, VDB or VDB-File 2. Add ObjParm to geo and enable volume parameter (choose the right type) 3. a redshift light - because only redshift light can contribute to volume That is! 1 Quote Link to comment Share on other sites More sharing options...
jingaa Posted November 3, 2016 Author Share Posted November 3, 2016 Hey nybte thanx for answer and this is what i did... cached the pyro, palayed little bit with volumevop , converted to vdb (convert type VDB, vdb class no change) , added ObjParm and Volume is enabled (volume type is i tried both way also) added material as rs volume and the result is negative oh added rslight sun to scene only Quote Link to comment Share on other sites More sharing options...
jingaa Posted November 3, 2016 Author Share Posted November 3, 2016 Ok i found it lol I changed the COnvert VDB to Volume and clicked on the Split Disjoint Volumes, on the geometro Redshift OBJ Volume i changed the Volume Type to Volume/VDB Houdini Primiteve and everything is cool now.... thank you for help man!!! 1 Quote Link to comment Share on other sites More sharing options...
