pasto Posted November 4, 2016 Share Posted November 4, 2016 Hello, I am just trying to install Redshift on Houdini indie 15.5 and where Octane is already installed. I guess that the order in the houdini.env file is important because I lose one or the other depending on the order I put the PATH and HOUDINI_PATH variables. I guess it just reads the last one. Is there a way to install both or should I modify the .env each time I want to switch of render engine ? Thanx for your help. Quote Link to comment Share on other sites More sharing options...
mosssi Posted November 5, 2016 Share Posted November 5, 2016 I didn't use redshift yet but I know rohandalvi installed and used both so you can massage him and post the result. http://forums.odforce.net/profile/1625-rohandalvi/ Quote Link to comment Share on other sites More sharing options...
pasto Posted November 5, 2016 Author Share Posted November 5, 2016 Thanx Mossi that's the first thing I did ! But his installation is quite messy also. Quote Link to comment Share on other sites More sharing options...
pasto Posted November 5, 2016 Author Share Posted November 5, 2016 Fot information here is the answer the developper : You can install at the same time several rendering plugins in Houdini, but you need to set all the config paths in the same variable, separated by semicolons. For example: PATH = “C:/ProgramData/Redshift/bin;C/Path_to_Octane_plugin/bin;$PATH” HOUDINI_PATH = “C:/ProgramData/Redshift/Plugins/Houdini/15.5.565;C/Path_to_Octane_plugin;&” Cheers 3 Quote Link to comment Share on other sites More sharing options...
