Various R&D's
rsd
Just shaping.
The shapes were simulated as a crowd, then a single actor were chosen at time.
No keyframe animation were used for particle manipulating. They were driven by additional attribute "passivity", so there is random delay for each particle, before they go to the goal.
Edited by rsd
  • Like 2
Portals.
I put this shader off for a long time. It's originally from Renderman Stupid Tricks.
I implemented all features:
* sight teleportation
* lighting teleportation
* shadow teleportation
* transformation
* geometry (displace) teleportation
Though I can't get geometry teleportation work well: mesh have to be teared, but intermediate polygons are stretching between portals, even with redicing.
  • Like 5
  • 2 weeks later...
  • 3 months later...
Hello @rsd love your R&Ds! specially the voronoi glass one, I started learning mantra and want to try to achieve something similar, didnt know that points could be rendered, I did a quick test with a scattered sphere and a mantra shader builder with displacement but cant get the displacement to work, I also played with settings on the obj with no luck, can you share some tips to achieve deformations on points like that?
Thanks!
Hey @caskal.
The idea of worley noise is to use distance to the nth-closest point from randomly generated point cloud as a value. See https://en.wikipedia.org/wiki/Worley_noise
To get controllable worley noise you need to pass your own point cloud to the shader. It can be done via Point Cloud Open: query a single point from the point cloud at current world position (the same space the point cloud saved in) and then compute distance to it.
Voronoi diagram is done by using an attribute from the queried point to color the current cell.
