sessionbeer Posted November 10, 2016 Share Posted November 10, 2016 (edited) Hello, Is anyone able to point out where I am going wrong here? Ideally I would like the boxes of different scales to stack up one on top of another. In another package, using python on a series of boxes I get the desired stacking effect. When I try to convert the python to vex it's not working as I'd hoped. I suspect it's a really small oversight on my behalf but it would be really helpful for me to understand where I'm doing wrong. My Python code # Example Python code def main(): list = op.GetObjects() new = Vector(0) for object in list: pos = object.GetPos() scale = object.GetScale() new.y = new.y + scale.y + pos.y #Set new position to new object.SetPos(new) #Update new new.y = new.y + scale.y - pos.y My Vex code run in Detail mode vector new = 0; for (int i = 0; i < (@numpt); i++){ vector pos = point(0, "P", i); vector scale = point(0, "scale", i); new.y = new.y + scale.y + pos.y; setpointattrib(0, "P", i, new); new.y = new.y + scale.y - pos.y; } Thank you stacking_up.hip Edited November 10, 2016 by sessionbeer Quote Link to comment Share on other sites More sharing options...
dchow1992 Posted November 10, 2016 Share Posted November 10, 2016 (edited) //point wrangle @P.y += v@scale.y; not sure if this is a small example of a larger problem you're trying to solve. sorry if this is obvious and not what you're looking for if you still want to use a detail wrangle for (int i = 0; i < (@numpt); i++) { vector pos = point(0, "P", i); vector scale = point(0, "scale", i); pos.y += scale.y; setpointattrib(0, "P", i, pos); } Edited November 10, 2016 by dchow1992 Quote Link to comment Share on other sites More sharing options...
sessionbeer Posted November 10, 2016 Author Share Posted November 10, 2016 Thanks for taking a look @dchow1992 With that code the boxes won't stack one on top of another, they simply move up the size of their scale.y I'm looking to get boxes of different scales to sit one on top of another. Quote Link to comment Share on other sites More sharing options...
Zybrand Posted November 10, 2016 Share Posted November 10, 2016 Hey Sessionbeer, Slightly different setup but it works on a detail wrangle: //get start point vector new = point(0,"P",0); for (int i = 0; i < @numpt; i++){ if(i == 0) // skip first point continue; vector scale = point(0, "scale", i); vector prev_scale = point(0, "scale", i-1); //get the height fron current and prev_scale combined new.y = new.y + ((scale.y + prev_scale.y)*0.5); setpointattrib(0, "P", i, new); } 1 Quote Link to comment Share on other sites More sharing options...
sessionbeer Posted November 12, 2016 Author Share Posted November 12, 2016 Thanks @Zybrand That worked out great! 1 Quote Link to comment Share on other sites More sharing options...
Atom Posted November 12, 2016 Share Posted November 12, 2016 Just a note that when you run VEX in Detail mode you lose the multi-processor benefit of VEX. So you may not see a big performance benefit converting from Python to VEX in this case. Quote Link to comment Share on other sites More sharing options...
