houdini_collison -smoke problem
vfxing123
Wait for an answer from an expert here, but what you can do is to add point velocity before the fluid source node in your collision geo. This will generate an addiotional volume (collisionvel) that will help the collision. You can initialize this velocity with vectors going parallel to the surface, so you can knida direct the flames to wherever you want
Edited by mine
