measuring max min temp/fuel in fluid source?
catchyid
In order to set parameter "Pyro Solver --> Combustion --> Ignition Temperature", one must measure the sourced Temperature in the scene, but SOP Fluid Source does not specify it explicitly, i.e. Fluid Source node just defines some parameters like temperature/fuel but there is no way to really measure how much fuel/temperature is added.
Is there a way to measure how much temperature (i.e. temperature values across the volume), or fuel produced by SOP Fluid Source node?
Thanks
What about using normalize field when you use source fluid in dop and use the multiplier to determine max value?
you can also inspect the min max field value on sop level in spreadsheet-intristic prims attribute or dcatter some points and do volume sample
That toggle doesn't actually normalize the source like that.  It is normalizing the amount that is sourced in regards to the timestep, so if you have 4 substeps - each substep the sources would get multiplied by 1/4 to compensate.
