Tiling spiral
7on7on
I think your spiral rotation is just slightly out of synch with the SHOP rotation value on the z-axis. You have 40, try 45.56. You may have to dial in this number each time you change the radius of the tube.
Thanks Atom, you're right
The cylinder uv are exactly unfold between 0 to 1 in u and 0 to 1 in u, which is similar to a simple grid. But when i put the pattern on a grid, i can repeat the pattern with any angle and is work. Why ?
For the effect i want to achieve i need to vary the angle... i can't use a fixe angle as 45.56
Ok, sometimes you just need to sleep.
I put a twist after the uvprojet at sop level. And now, i can animate the twist to vary the spiral angle.This is not the same because the spiral is a mask which drive other shaders. And these shaders must be in the undeformed cylinder. But i can live with that. Thx
