when converting primitives which have attribute
shinsso
Hi, when I wanted some primitives to be converted to polygons,
there was an issue.
Before converting, I set primitive typed-attribute on the primitives because I could seperate each objects.
But, the attributes didn't exist after converting.
Even though I used attribute copy node, it didn't match properly.
Can I use the attribute regardless of converting?
No, you can't use it if it does not exist.
How are you converting? I just used the Convert node and my primitive attribute still exists on the resulting primitives.
Post an example file with the problem, if you can?
