Python: how to determine if a node is a ROP node
jonp
Maybe I'm missing it, as I only searched for about 10 minutes, but how does one determine if a node is of type hou.RopNode?
For example, the rop_alembic SOP node is of type "rop_alembic", but its category is "Sop".  How do I determine that it's actually a render node?
One possible answer is to do this:
is_rop = hasattr(node, 'render')
...but that can give false positives.
-Jon
That is true, but when I try to access 'geometry()' on that node, it will raise an error that mentions it being a 'hou.RopNode' class!  How do I get to that type definition myself?  That seems like the magic bullet.
There is misleading collision between Python types and Houdini operator types. In Houdini terms (by calling hou.Node.type() method), rop_geometry is a Sop node, also true inside Operator Type Manager window:
In Python terms, this node will be an instance of hou.RopNode, no matter where it is:
isinstance(node, hou.RopNode)
type(node) == hou.RopNode
Before now, I was sure that every node within one network will be same type for both Houdini and Python.
Edited by f1480187
