MPlay Grab Audio From Timeline?
Atom
Hi All,
I have a long animation with audio.
I have set my start frame to 810 and my end frame to 1010.
I create a flipbook so can check my lip synch in real time.
However, there is no audio in MPlay..?
I navigate the menu Anim\Load Audio there is no option to read the audio from the timeline.
Is there a way to configure MPlay to use the audio from the timeline directly?
Shouldn't this just be the default?
Edited by Atom
R-click of the flipbook with new setting, click the flipbook, there is the audio filename in the window of Render Flipbook, u can upload the audio file here ( .wav ), and also u can offset the audio frame. When u do the flipbook , it will automatically render ur scene with the audio .
