packed primitives and materials
I am struggling with getting material variations with packed primitives when using a Copy SOP.
The example is a forest, e.g. a fairly complex tree with 100ks of leaves. With the Instance object, it was possible to assign a shop_materialpath and material_override to points, e.g. to change BaseColor. With packed primitives and the Copy SOP, adding a material_override causes mantra to completely ignore the assigned material. A way to get around this is to assign a material_stylesheet. Unfortunately, material_stylesheet causes mantra to unpack all the packed primitives which quickly exhausts all available memory.
Here is an example file: https://drive.google.com/file/d/0B3SRWSd2MwvPQndFcWhOTUlrcVE/view?usp=sharing (25M)
Any ideas would be appreciated.
Edited by Activate
It works but it causes unpacking of primitives in mantra, so that the geometry is no longer shared. It significantly increases render times and memory. That's a problem with material stylesheets. I believe they work effectively only for light-weight geometry, e.g. crowds.
So, far the only solution I have been able to get to work is to assign different materials (based on some thresholds on the parameters) rather than doing full parameterized materials, e.g. make leaves look more wilted if they have less vigor, etc.
