ERROR ON FILE NAMING WHEN CACHING FILE FOR SLOWMOTION
anto187
hello all,
is somebody has solved problem like this,
when i substepping the simulation into 10 substep on the dopnetwork, then setup the step playback frame into 0.1, then i write the cache with step 0.1,
i got error number sequence. i had try with freeware for batching rename, but still didnt get the patern number because every 10 frame, the lenght of the filename was difference. its okay if the range under 100 framets
but my frame above 3000 fame, its paintfully if i manualy rename the file.
is there anyone ever had solve this case?
thanks all.
