Homer0 Posted December 16, 2016 Share Posted December 16, 2016 Hi all, i've purchased the Helloluxx training "Tea and Cookies", and i've encountered a problem with the Polyextrude, since the course was made in Houdini 13, when you could use local variables in the parameters. Problem is, if i try to drive the extrusion distance based on the object color, it works only if the "Divide into" is set to Individual components; which in my case is not usefull (i'm doing a tea spoon, trying to give it an extrusion higher in the handle than in the tip). Any workaround for this issue? Thanks ^^ Quote Link to comment Share on other sites More sharing options...
Sepu Posted December 16, 2016 Share Posted December 16, 2016 Here it works the same way. extrusion.hipnc 1 Quote Link to comment Share on other sites More sharing options...
Homer0 Posted December 17, 2016 Author Share Posted December 17, 2016 (edited) unfortunately it doesn't work. As i said, it works good when the geometry Y is located on Y=0. If you have a geometry with some point above 0 and others below; this methos flattens everything to Y=0 before it starts. The solution would be to move the Point position along their normal, adding the value to the existing position; but sadly i don't know how to do such a thing. Here's the scene: Spoon.hipnc Edited December 17, 2016 by Homer0 Quote Link to comment Share on other sites More sharing options...
Sepu Posted December 17, 2016 Share Posted December 17, 2016 I see... then use @P.y += @N.y * @Cd.r; 1 Quote Link to comment Share on other sites More sharing options...
Homer0 Posted December 18, 2016 Author Share Posted December 18, 2016 Yep, now it works. Another solution that a user suggested on another forum was to use Displace Along Normal vop, tried that and basically it's the same ^^ Btw, i'm trying to undestard the VEX stuff, but i couldn't find a list of parameter to use. I searched in the help with no luck. Is there somewhere a list with all the parameters like @P , @N, @Cd, etc.? Also i noticed, in your expression, that the + makes all the difference, correct me if i'm wrong: @P.y = @N.y * @Cd.r; = the Y position is egual to the Y normal multiplied for the red color channel @P.y += @N.y * @Cd.r; = the Y position is egual to the Y normal multiplied for the red color channel, added to the current Y position Quote Link to comment Share on other sites More sharing options...
Sepu Posted December 18, 2016 Share Posted December 18, 2016 (edited) Hi, Yes your assumptions are correct. You could also do it in VOPs with the displace along the normal. which basically is what I did but just with VEX, sometimes is just quicker to write some code than going to VOPs. @P.y = @P.y + @N.y * @Cd.r; the += is just a shorthand operator Here are some site that might help you as well. https://www.sidefx.com/docs/houdini15.5/vex/snippets https://www.sidefx.com/docs/houdini15.5/vex/lang Edited December 18, 2016 by Sepu 1 Quote Link to comment Share on other sites More sharing options...
Homer0 Posted December 18, 2016 Author Share Posted December 18, 2016 I see. Thanks a lot for all the info ^^ Quote Link to comment Share on other sites More sharing options...
