How to access an attribute inside CHOPs for parameters?
magneto
Thanks Edward, I used the $C inside a point expression. Because I have a lag point attribute and I want to load this value into Lag parameter for each point. Geometry CHOP will bring the attribute into CHOPs but not alter the parameter on a CHOP node unless I am missing something.
Basically I want to vary CHOP node parameters for each point separately.
That then depends on whether the parameter in question is evaluated per channel or not. This varies drastically depending on the particular node. In the Lag CHOP case, that's true. So then you can just use a point() expression even.
