Janmansilver Posted December 29, 2016 Share Posted December 29, 2016 How do I vary the stifness of cloth? All the documentation and examples I can find are for old versions of Houdini, the new Cloth solver is a mystery. I would like create/paint attributes and the points the tell the solver that these areas should not bend as much. But how is this done? Quote Link to comment Share on other sites More sharing options...
stickman Posted December 29, 2016 Share Posted December 29, 2016 Create a group / groups (however you need - paint, selection, etc.) then drive the stiffness with them Cloth_groups.hiplc Quote Link to comment Share on other sites More sharing options...
Guest tar Posted December 29, 2016 Share Posted December 29, 2016 @Janmansilver not sure where you are looking but the documentation has all this and is up to date. http://www.sidefx.com/docs/houdini//cloth/changing_cloth_look The primitive attributes that multiply the Stretch, Shear, Weak Bend, and Strong Bendmodels are: Parameter Type Name Stiffness float shellstretchstiffness Damping float shellstretchdamping Shear Stiffness float shellshearstiffness Shear Damping float shellsheardamping Weak Bend Stiffness float shellweakbendstiffness Weak Bend Damping float shellweakbenddamping Strong Bend Stiffness float shellstrongbendstiffness Strong Bend Damping float shellstrongbenddamping Quote Link to comment Share on other sites More sharing options...
Janmansilver Posted December 29, 2016 Author Share Posted December 29, 2016 Thanks I used shellstretchstiffness with an attribute create and a paint sop and then an attribute promote points to primitives and this seems to work just fine. Thanks. :-) Quote Link to comment Share on other sites More sharing options...
JDee Posted August 18, 2017 Share Posted August 18, 2017 (edited) Does anyone know where are those control attributes now in H16 ? Testing my old files from H15 and they are just not working anymore, also they took it of from the new documentation ? BTW found the new updated cloth object in H16 just horrible, unpredictable and uncontrollable comparing to H15. Why is that happened, may be just not to update something that just worked fine ? Edited August 18, 2017 by JDee Quote Link to comment Share on other sites More sharing options...
