j00ey Posted January 4, 2017 Share Posted January 4, 2017 (edited) I have another problem now. Not really my day! I have some geometry on which I've stored some height information as string detail attributes, eg '45.40000152587890625 45.450000762939453125 45.479999542236328125 45.529998779296875 45.5699996948242187' Now I want to split each string into an array of strings, convert each of those to a float and store those in arrays. The problem is that when I do so, I end up with eg '45.40 45.45 45.47 45.52 45.56'. It's storing only 2 decimal places and I can't figure out why. You can see in the screengrab the difference. Attached is a test file Thanks for looking odforce_decimal_precision.hiplc Edited January 4, 2017 by j00ey typo Quote Link to comment Share on other sites More sharing options...
holycause Posted January 4, 2017 Share Posted January 4, 2017 (edited) edit, nevermind, looked at the wrong node the debug node is returning the right data Edited January 4, 2017 by holycause Quote Link to comment Share on other sites More sharing options...
j00ey Posted January 4, 2017 Author Share Posted January 4, 2017 Ah, I was just about to fire up an old version. Thanks for looking anyway. Quote Link to comment Share on other sites More sharing options...
iamyog Posted January 6, 2017 Share Posted January 6, 2017 I do not actually have an answer but just wanted to share a thing: I'm not sure the lost of precision is coming from the conversion from string. if you run @base = 123456789; @div = pow(10, 9); @RESULT = @base / @div; RESULT will return 0.1234567 instead of 0.123456789 not sure where to go from there though. Quote Link to comment Share on other sites More sharing options...
dimovfx Posted January 6, 2017 Share Posted January 6, 2017 also if you try @result = atof("12.3456789"); the @result will be 12.3457 so there is precision rounding in this function. Quote Link to comment Share on other sites More sharing options...
j00ey Posted January 6, 2017 Author Share Posted January 6, 2017 weirdly though if you do @result = 12.3456789; the @result is 12.3457, so the rounding isn't even happening in the atof function. Note also this is 4 decimal places but... if you do as iamyog says @base = 123456789; @div = pow(10, 9); @RESULT = @base / @div; the result is 0.123457, ie 6 decimal places. Both though have 6 non zero digits. In my results from the original posts I was getting a maximum of 4 non zero digits. Very odd Quote Link to comment Share on other sites More sharing options...
dimovfx Posted January 6, 2017 Share Posted January 6, 2017 (edited) interesting... @result = 0.123456789; = 0.123457 @result = 1.123456789; = 1.12346 @result = 12.123456789; = 12.1235 ... @result = 123456.123456789; = 123456.1 ... and so on. wonder if this is what shows or what really is stored in the attrib edit: @result = 123456.123456789; @test = @result - 123456; returns 0.123457 so i guess this is just visualisation rounding Edited January 6, 2017 by sasho78 Quote Link to comment Share on other sites More sharing options...
acey195 Posted January 10, 2017 Share Posted January 10, 2017 this is just single floating point accuracy, which is generally accepted to be 6 digits I think. even though Houdini floats are really 32 bit by default (in wrangles), which can represent more digits accurately, I guess its just the same baseline that is chosen. Quote Link to comment Share on other sites More sharing options...
j00ey Posted January 11, 2017 Author Share Posted January 11, 2017 I see, but I'm only getting 4 digits in my arrays. You can see in the jpg attachment on the original post. It's actually fine for my purposes, I was just curious as to why it happened. Thanks for the info. Quote Link to comment Share on other sites More sharing options...
f1480187 Posted January 12, 2017 Share Posted January 12, 2017 (edited) 1) Houdini displays floats in "g" form, which is shorter representation. 1.23456789 1.23457 12.3456789 12.3457 123.456789 123.457 1234.56789 1234.57 1234567.89 1.23457e+06 0.0000123456789 1.23457e-05 2) It seems that VEX ignores different precision and always converts floats to 32 bits. It's the case for other Houdini nodes, but not all of them. I lost precision with Point SOP, but Attribute works well. I guess, it depends on value types used inside HDK. precision.hipnc 3) That number "45.479999542236328125" looks like a single precision float stored in "double-precision" style. So, it is just a 32-bit value of 45.48. And half of the digits are rounding error garbage and may vary across different computers (if string generated again). You will loose nothing restoring it as 32-bit floats. But if the numbers looks as precise as doubles, like "45.479999999999997", you loose precision. It's all only my thoughts, I may be wrong somewhere. Edited January 12, 2017 by f1480187 Quote Link to comment Share on other sites More sharing options...
