fuse -> subdivide (bug?) simple question!!
I have some issues with the FUSE before SUBDIVIDE sop and  I think it might be a bug.
Its realy simple... -> Platonic Soccerball -> create Unique Points -> assemble name attr. -> (foreachSubnet.-..Extrude) -> Fuse -> subdivide.
After that it just doesnt seems to work probably.
see example:
soccerball tst.hip
Edited by squardis
Have you tried subdividing only the front and side polygons? output front group and side group on the polyextrude. Then on the subdivide node set extrudeFront extrudeSide in the group parameter. Don't have Houdini right now, but this might be worth a try.
Cheers,
WD
