squardis Posted January 7, 2017 Share Posted January 7, 2017 (edited) Hi, I have some issues with the FUSE before SUBDIVIDE sop and I think it might be a bug. Its realy simple... -> Platonic Soccerball -> create Unique Points -> assemble name attr. -> (foreachSubnet.-..Extrude) -> Fuse -> subdivide. After that it just doesnt seems to work probably. see example: soccerball tst.hipFetching info... Edited January 7, 2017 by squardis Quote Link to comment Share on other sites More sharing options...
squardis Posted January 7, 2017 Author Share Posted January 7, 2017 SOLUTION: I foud it.... don't use OUTPUT BACK. manifold geo: <- is not possible? Quote Link to comment Share on other sites More sharing options...
woodenduck Posted January 9, 2017 Share Posted January 9, 2017 Have you tried subdividing only the front and side polygons? output front group and side group on the polyextrude. Then on the subdivide node set extrudeFront extrudeSide in the group parameter. Don't have Houdini right now, but this might be worth a try. Cheers, WD 1 Quote Link to comment Share on other sites More sharing options...
