back face deleting from other object
murathan altunsoy
You don't need last cycle. It's repeating same thing N times. Delete it and everything will work fast.
For the minor improvements, there is no need to expand all points into 0..@numpt range array simply to iterate over it. Use regular for loop. uzak doesn't need to be array to find minimum from it. Override existing minimum inside loop.
float uzak = 1;
for (int i = 0; i < npoints(1); i++)
    vector pos = point(1, "P", i);
    float query = dot(@N, normalize(@P - pos));
    uzak = min(uzak, query);
if (uzak > 0)
    removepoint(0, @ptnum);
uzak.hipnc
Edited by f1480187
float uzak = 1;
if (uzak > 0)
uzak.hipnc
Thank you F1. This is  really good answer.
