HITIMPULSE ATTRIBUTE FOR FLIP
newbee
I am trying to use gasimpacttoattributes to create some hit impulse attribute for flip
but it seems like it doesn't work because i have no impact data..
does anyone know how to generate impact data and get hitimpulse to work for flip?
the only thread i found online was
https://www.sidefx.com/forum/topic/37420/?page=1#post-170605
here is a simple scene file to test
hitimpulse.hipncFetching info...
if you check the spreadsheet u can see that the hitimpulse is 0
Edited by newbee
Thanks for the setup I always wondered how to generate impact data with FLIP.
So what does the impulse value represent? Is it speed on impact?
Also, do you know what the value of the flags represent? I mainly see a 0 and a 4.
hitimpulse records strength of collision.
The values of hitimpulse depends on the force with which flip impacts the collider
I put together a quick test and noticed that:
if you increase flip incoming velocity and hit the collision object with more force the hitimpulse will have a higher range
Edited by newbee
